Anyone tell me the stock length.....
Old May 5, 2002 | 02:21 AM
90FormulaL98's Avatar
Car: 1990 Formula 350
Engine: L98 350
of a rear 24MM Formula sway bar endlink. I need to order them.
Thanks, Gary
Old May 5, 2002 | 04:41 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
24 mm Formula/Camaro...same thing. I measured mine, stock front and rear, and got 2 1/4". The replacement ones I got from Energy Suspension measured 2 5/8".....FYI.
Old May 5, 2002 | 02:12 PM
Engine: L98 350
Thanks, Do they sell th 2-1/4 or are the 2-5/8 fine to use?
Old May 5, 2002 | 04:22 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
If not, you could buy them and cut the sleeves to what you want. The website is at http://www.energysuspension.com if you want to look at their catalog.. there's no "pontiac firebird" area, so just go under chevy camaro.
Old May 5, 2002 | 07:02 PM
ebmiller88's Avatar
From the site, the closest size they have are 2 3/8". They have size 2" on the shorter side and 2 5/8" on the longer side. I go with TomP, just cut it if you need to. This has been brought up before, and the consensus was that unless you are road racing you don't need it to be perfect.
The site says this:
TO FIT/SELECT PROPER SET-
Vehicle must be on level ground (not jacked up) with wheels supporting it. Make sure stabilizer bar end eyelet (B) is parallel with the control arm (C). Many times they are not. You may be required to use a slightly longer or shorter sleeve length than the original. Measure sleeve length (A) and compare to the chart to find the correct set.
Size yours accordingly.
Ed
Old May 6, 2002 | 05:02 PM
Engine: L98 350
Cool that will work. Thanks.
Jeremys87
Jul 14, 2022 09:08 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Genopsyde
Oct 7, 2015 08:35 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
