will a 285/40/17 fit on front of my 91z28
Old May 5, 2002 | 04:47 PM
BOTTLEDZ28's Avatar
Transmission: A4
I have 17x9 SS wheels with 2" spacers for the front and want to know if a 285/40/17 will fit without rubbing? anybody use this size. how about the back with a 4th gen rear
Old May 8, 2002 | 08:17 PM
realfst383's Avatar
You have a similar situation to mine, let ME ask YOU a question? You said you used front spacers? Where did you get them? And What about the rear rims, did you need spacers for those too? As far as the tires go, my buddy is running 275/40/17, and they do rub quite a bit in the front. The rear, however, are in fact 285's and they work fine with a ''regular'' 3rd gen rear end.
Old May 8, 2002 | 08:19 PM
BOTTLEDZ28's Avatar
Transmission: A4
i got my front 2" spacers from SPD. I put a 4th gen rear in my car so I do not need spacers for the rear.
Old May 9, 2002 | 12:25 AM
BillyB4C's Avatar
I have 285's on 9.5 wheels up front and they rub quite a bit. They rub the ground efects when turning all the way to the left or right. It's not as bad now since the tires have worn away some of the plastic. My car is lowered about 1.5 inches. They should fit just fine on the rear. I have 315's with 11 inch wheels on the back.
Old May 12, 2002 | 01:44 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
You guys running 2" front adaptors must have wheels that are VERY close to the shock. I have 2.25" and there is barely any room.
BillyB4C:
NICE car!! :hail:
Old May 13, 2002 | 02:01 AM
BillyB4C's Avatar
BTW i am running the 2.25 spacers up front.
Omega: Thanks. Heres a link to some more pictures.
http://www.1le.org/car_of_the_month.htm
Old May 13, 2002 | 08:34 AM
Omega's Avatar
Engine: LS1 / LS3
BillyB4C:
I am not a huge camaro fan, but that is one MEAN machine!
Your front wheels seem to fit in the fender a lot better than mine do... are the camaro fender flares bigger than the firebird?
Street Lethal
Apr 30, 2019 12:14 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
