how much stiffer are convertible springs?
Old May 12, 2002 | 06:34 PM
BigL350's Avatar
I read that the front springs on convertibles are stiffer to make up for chassis flex, but how much stiffer are they? The situation is this....I'm putting Eibach pro-kit springs in my vert, more for the lowering than for performance, but I want use the stock springs from the vert in my malibu. In the front, I want to cut half a coil, and in the back I'll leave them as is with the rubber spring isolator needed to make them work in G-bodies. I'm not looking to go autocrossing or anything, I'm just trying to use what I got to make it handle less like a yacht. At the same time I will be rebuilding the front end with Performance Suspension Components graphite impregnated polyurethane bushings, KYB shocks and front and rear sway bars. I know cutting coils increases the spring rate, so am I asking for trouble if I use the convertible springs?
Old May 12, 2002 | 09:02 PM
camaro6spd's Avatar
stiffer springs would not help chassis flex....if ne thing they would cause more by not letting the suspenstion absorb the bumps.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Lanz06
Sep 14, 2015 07:16 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
