lowering front this weekend..anything specialto tell when getting alignment??
Old May 18, 2002 | 04:06 AM
2ponchos's Avatar
going to lower the front of my car this weekend.. is there anything when i take it to get aligned to tell the person doing it?? do i have to tell them its lowered or anything or any special specs?? thanks
Attached Thumbnails lowering front this weekend..anything  specialto tell when getting alignment??-2ndwash_0004.jpg
Old May 18, 2002 | 10:52 AM
82camaro's Avatar
Car: 82 camaro SC
I good alignment tech will see it's lowered and give you the option of some better specs(that's what I always did). Tell them you want:
-.5 degree camber left and right
4.5 degrees caster left
5.0 degrees caster right
+ 1/16 inch toe
If they can't get both sides to -.5 degree camber, have them both set the same. For instance, if they can only get the left camber to -.3, have them put both sides at -.3--being equal is important.
Caster should have the .5 less on the left side to compensate for the crown on the road.
Old May 18, 2002 | 04:31 PM
2ponchos's Avatar
thanks!!!
customblackbird
Aug 15, 2021 10:16 PM
Amillionoh7
May 24, 2020 08:01 AM
Street Lethal
Aug 14, 2015 08:25 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
