ET Streets on back but up front.......
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
I know you're not suppossed to mix bias ply and radial tires but it seems so many people are doing it. I can get a pair of skinny Khumos for about $70 but they're radials. Is it worth it to save the money or should I just get M/T Sportsman Fronts? Is it really that bad(squirrly) at speed with the radials on front?
The car will see some street use and occasional short parkway use at lower speeds(50mph).
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
My front tires are radial. Back tires are Hoosier drag slicks.
You're not supposed to mix them on the same axle but front to rear is fine.
Engine: Chevy ZZ4
That's what I've been hearing but just wanted to double check. I still don't think your really suppossed to mix them at all but for what we use them for I guess it's not so bad. Thanks
Engine: Chevy ZZ4
That's just what I did this weekend. Futura 165/15's for a whole $25 each
