front end popping like crazy!!!
Car: '88 GTA
Engine: L-98
ok i put new ball joints and idler arm in like a month ago cause it was popping a lil bit..... now it pops 2x more and even louder........ and yes i did recheck my work, everything is tight lubed and seated correctly......sometimes it even sounds like a haunted house door its really strange it inly does this while moving if im stopped and have someone turn the wheel while i listen it dosent do it. Im thinking maybe upper shock mounts but they look ok i guess so i dunno any help you all could give would be greatly appreciated
im scared im gonna lose a tire while drivin kinda scary!
Car: 1991 Camaro Z28
Hey,
Take your car to a shop and have the alignment checked if you didn't after you installed the new parts. Most likely when you changed the parts it messed it up. Happened that way on mine. after I switched out all the steering parts it hopped around corners and popped alot.
David
David
Terrell351
Jun 13, 2021 01:13 PM
