Anyone have long tube headers and a spohn torque arm?
Old Jun 12, 2002 | 07:27 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I need to know how you ran your custom y-pipe. I can't get my torque arm at all right now because of the crossmember. Also, do any of you with the spohn TA have true duals that exit in front of the rear?
Old Jun 24, 2002 | 08:02 PM
xookered's Avatar
I've got hooker lt's. The key is getting rid of the y-pipe and running duals. The headers will come down right beside the transmission pan on either side. Run each pipe under the torque arm crossmember and use turn downs to dump the exhaust right before the rear axle. I'm running a dual 3-inch x-pipe setup so you know there has to be clearance. Not much, but enough.
Old Jun 24, 2002 | 08:57 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Is there any way you could send me pics of your set up?
Old Jun 25, 2002 | 05:44 AM
xookered's Avatar
94, do a search for x pipe picture and then scroll down to 3" x pipe, this is Momar's setup. This was my inspiration. The only difference is my setup is a tad bit lower than his, for clearance purposes. But I have never had a problem with ground clearance.
italiano67
Dec 11, 2016 09:21 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
