Where to get stock replacement springs?
Old Jun 18, 2002 | 11:12 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
Alright, I was thinking about lowering my car but I'm starting to want a completely stock appearance now. I have an '87 Z28. I'm thinking I want some IROC springs or something... better performance but no lowering. I'm pretty sure Moog makes stock replacements, but I can't find them anywhere on the net. Does anyone know where maybe I can get some part numbers? Or can I just go into a pep boys or someplace like that and order them there? And what springs should I go with? '90 IROC springs? '92 Z28 springs? Or is there no difference? And I don't want to get any used springs, I want brand new ones that don't have all these miles on them. Also, does anyone know a price on them? Thanks.
Old Jun 19, 2002 | 07:08 AM
ede's Avatar
ede
there was no 87 z28s only irocz if you have a z28/iroc you already have what you want. if you have a camaro with pnly z28 badges you don't have a real one, check the rpos. at any rate you can buy replacements springs about anywhere that sells parts, have you tried calling around your area and asking on avaiability and pricing
Old Jun 19, 2002 | 12:22 PM
Hg's Avatar
Hg
Car: '87 Z
Um, yeah there was an '87 Z28. I checked my VIN and RPO codes a long time ago and they say Z28. Check the tech data here https://www.thirdgen.org/newdesign/tech/techdb.shtml there is an '87 Z28, they were 52,863 of the total production run of 137,760. The normal Z28 wasn't available in 88-90.
Old Jun 19, 2002 | 01:56 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
If you goto a generic auto store you will get standard replacement springs (read: crap). Moog makes all sorts of springs and they will be able to help you pick the right springs. If you look here: http://www.geocities.com/rgades/Sping.html?985231546900 you will find the list of codes and part numbers. As you can see, only 2 springs are left that you can order. I went with the 14029399. It is a very stiff spring and now my car handles like a dream.
customblackbird
Aug 15, 2021 10:16 PM
sailtexas186548
Aug 26, 2015 03:32 PM
TheExaminer
Aug 25, 2015 07:34 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
marcusaw
Aug 10, 2015 08:13 AM
