Manual Steering Box?
Old Jun 19, 2002 | 09:24 PM
Matt383's Avatar
I've heard that an S-10 Gear Box is a direct bolt in. My question is what year(s) s-10 will work in an '86 camaro? and also what pitman arm should I use- the s-10 or camaro?
Also for those of you who have done this- good/bad/etc. Any performance gains? This is not my daily driver and will have skinnies on the front.
Matt
Old Jun 20, 2002 | 09:08 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Any year should fit. Mine is from an 87. You should use the f-body pitman arm. It has a slightly different angle than the S10.
The performance gain is in weight saving. Removing the power steering box, hoses, fluid, pump and brackets and cooler if equiped, saves a lot of weight from the front of the car
1992 Trans Am
May 10, 2023 07:19 PM
Amillionoh7
May 24, 2020 08:01 AM
MyRedCamaro
Dec 29, 2015 05:16 AM
backtothe80s
Sep 5, 2015 12:39 AM
zayne0
Aug 24, 2015 07:22 PM
