Can I install SFC's?
Old Jun 21, 2002 | 11:15 AM
Dustin Mustangs's Avatar
Car: I
Engine: Taunt
Transmission: Mustangs
I want a set of SFC's on my car and I am wondering if I could do it myself. I have access to both styles of welders; mig and tig, right? Which one of these will I have to use to do this? I have heard you can't use jackstands for this because the chassis needs to be normally loaded when you weld them on, is this true? Has anyone pulled this off in their garage before? Or do I need to pay someone to do it that has a lift?
Old Jun 21, 2002 | 11:57 AM
Brian'sIROC's Avatar
I wouldn't recomend doing it without all 4 tires on the ground/lift.
Old Jun 21, 2002 | 04:55 PM
keen88gta
Guest
Posts: n/a
Definitly go with the tig weld. It is much stronger by far. And unless you can crawl under your car and get all your welding tools under there I would suggest bringing it to a shop and having them do it on a lift.
just my .02
Old Jun 22, 2002 | 08:53 AM
ops32's Avatar
Car: 1983 25th Anny Daytona 500 T/A
Engine: Stock...inoperative... 305
Transmission: Automatic
I just installed Jegster bolt-on "frame ties" (SFCs) yesterday. Had all wheels sitting on 2x6 wood ramps so car was level with weight on wheels. Took 2.5 hours to install both rails. I'll run them with the bolts for awhile, then have them welded on, too.
I should have pictures of the install on my website by the end of today.
Rob
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
kairles
Oct 26, 2015 09:13 PM
gixxer92
Sep 1, 2015 04:32 PM
