84 front caliper wont bleed
Old Jun 21, 2002 | 11:02 PM
1988bowtie's Avatar
A friend bought an 84 Z28 the other day. Today we changed front pads. The passenger side worked fine but the caliper locked up on the driver side. Picked up a rebuilt caliper and installed it, but we can't get it to bleed. We used a vacuum bleeder, tried using the pedal and even took the caliper off and couldn't get any fluid to bleed from the line. Resivoir is full and the pass. side brake still functions fine. What's going on? Plugged line? Bad master cyl. or combo valve? Did we forget something? Directions said to use the valve on the back of the comination valve to help fill the caliper but we couldn't get that to work. Help!!!
Old Jun 22, 2002 | 08:04 AM
1988bowtie's Avatar
Come on guys someone must know something about this system.
Old Jun 22, 2002 | 11:06 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
more than likely you got some blockage in the line. i would use some shop air and blow out the affected line. how about the flexible line(rubber)? is it new/old? it could also be an internally collapsed rubber hose.
Old Jun 22, 2002 | 12:54 PM
Andy Fanshawe's Avatar
Car: 91 camaro rs
Yep. I agree. Intenally collapsed rubber line.
The pressure wouldn't release to that caliper, so it would lock up. It wouldn't bleed either since there is no clear path to the caliper.
Did you check the "stuck" caliper when you took it off? Was it seized or not?
Andy.
Old Jun 22, 2002 | 04:31 PM
1988bowtie's Avatar
The caliper was not seized. Plan is to take the rubber line off and see if it bleeds from the steel line. If it does then change the rubber line. Thanks
1992rs/ss
Jan 31, 2025 05:10 PM
backtothe80s
Sep 5, 2015 12:39 AM
zayne0
Aug 24, 2015 07:22 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
