Pictures of Spohn TA (700R4)
Subscribe
Jun 22, 2002 | 09:24 PM
I'm looking for pictures of the Spohn Torque Arm for a Camaro with a 700R4 tranny. His web site doesn't have a picture of it. I would also like to see it installed and how low it sits.
Reply 0
Jun 22, 2002 | 11:45 PM
Here is a Spohn t/a before he made them with DS loops. This is one of the very first t/a's he made:
Reply 0
Jun 23, 2002 | 08:05 AM
Very nice Tom. Do you have a close up of the crossmember?
Reply 0
Jun 23, 2002 | 11:22 AM
This pic is for showing how I had to cut out a notch to clear my sfc. It is a funny angle but you might get the idea:
Here is a better view of the cross member, but with a T-5 now attached to it.
Reply 0
Jun 23, 2002 | 02:41 PM
Thanks.
What's the black rubber bumpy looking thing at the front covering up?
Reply 0
Jun 23, 2002 | 05:08 PM
That's where the torque arm slides in and out of the cross member. It is lubed and the rubber boot is a dust cover.
Reply 0
Jun 23, 2002 | 05:18 PM
I didn't know that, thanks Tom. You've been a source of good info. I can't wait to get mine.
Reply 0
Jun 24, 2002 | 05:51 PM
john, i could be wrong but i dont think the poly end will be the same as i just put mine on and it has more of a double swivel point and no boot as the one in the pic.
pete
ps i too cut one brace to clear my alston subframe connecters
Reply 0
Jun 24, 2002 | 09:01 PM
I ordered the rod end TA, not the poly Pete.
I don't know if it will be the same as the one pictured, he said it was a 1st design long ago.
I have Hotchkis SFC's, I'll let you guys know if it clears or I have to trim the crossmember.
Reply 0
Jun 25, 2002 | 10:10 PM
Good pics - I need to get a digital camera.
I installed mine (Spohn torque arm) about 4 months ago and it's a slightly different setup. The front mount is a Heim joint attached to a pivoting arm joined by a poly bushing to the trans cross-member.
I find that this setup with about -1.5 degrees of pinion angle really launches the car. My first to second shifts are very hard with very little wheelspin. I also have the lower control arms, the setup is very stable.
Reply 0
Subscribe
