Bear Brake questions
Old Jun 22, 2002 | 10:40 PM
maniacc's Avatar
OK, Ive read through a bunch of posts here on baer brakes, some people say that the 13" rotors will fit under stock iroc wheels and some say they won't...
I need to know if they will fit, before i place my order on monday.
Where can i find the best deal? (so far thunder racing is my choice)
thanks for any help
later
larry
Old Jun 22, 2002 | 10:45 PM
87transam5.7tpi's Avatar
go to bear's website. they have this template you can download to check, pretty cool
Old Jun 22, 2002 | 11:52 PM
Tom Keliher's Avatar
Definitely try the template out. You can download it, print it, glue it to stiff cardbaord, cut it to the correct size, and then check the fit of your wheel. I think Baer says it may work with some Camaro rims, it won't work with Pontiac rims. Here is a pic of the 13" Track system inside my 17" wheel. Notice the caliper, it gets even closer to the inside of the wheel as it goes in deeper. The stick-on wheel weights just barely clear the caliper on these 17" wheels. On a 16" wheel they would get knocked off.
Old Jun 23, 2002 | 12:06 AM
james_85Z28's Avatar
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
Have you installed the kit yet Tom? I have a set of loose 16" IROC wheels I could try out the 13" kit with if you don't mind.
Old Jun 23, 2002 | 09:03 AM
maniacc's Avatar
Thanks guys, i already tried the templates and thier are really close. They seem to fit, but i think it's alittle too close for my liking.
I need to know if the 13" track kit will fit with no modifications behind '88 Irocz 16" wheels. some here has had to attempt this.
thanks again
larry
Old Jun 23, 2002 | 11:14 AM
Engine: 3.6L
I have the Baer template but when it is out of scale went O print it out on my deskjet printer.
Old Jun 23, 2002 | 11:50 AM
maniacc's Avatar
Do you live close to Tom? If you guys could set it up to try a stock 16" iroc wheel on his car that would be cool!!!
The templates that i tried looked to close to call, i think i'll just get the sport set.
later
larry
Old Jun 23, 2002 | 11:54 AM
Engine: 3.6L
a couple hours away (1.5 ?). I've met him before at a club meeting.
Old Jun 23, 2002 | 07:25 PM
Rick89IROC's Avatar
I test fit one of my old 89 IROC 16x8 front wheels today and it contacts the caliper on my 13 inch Baer Track kit. I can slip the wheel over the studs, but when I tighten up the lug nuts I can't rotate the wheel at all.
Old Jun 23, 2002 | 09:17 PM
maniacc's Avatar
Thanks Rick, that's good to know...
I'll be ordering the 12" sport kit tomorrow. my right front caliper started hanging up today, off with the old, in with the new..
Where's the best prices???
Old Jun 23, 2002 | 10:18 PM
Rick89IROC's Avatar
I got mine from Paul at Thunder Racing. If Baer doesn't have a kit sitting on the self, it might take two to three weeks before you get them. Their is a $150 core charge for the spindles, but Baer sends you an UPS sticker, so you just put your old spindles in the box and put on the sticker and Baer picks up the shipping charge on sending your old spindles back to them.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
red90IROCls1
Aug 25, 2015 06:56 AM
redmaroz
Aug 16, 2015 11:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
