My car cant launch well will this help...
Old Jun 23, 2002 | 10:22 AM
mike89z's Avatar
Car: 89 Iroc-Z
Engine: 355
My car hasnt had anything replaced in the suspension so I was thinking new struts and shocks and some hotchkins trailing arms. Should these things alone help over my current setup (I know the shocks in there are bad by now). Any other ideas? The car has BFG drag radials so when I get up the track I think I will also lower the pressure in these too. Any thoughts are appreciated!
Old Jun 23, 2002 | 11:27 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
get some lower control arm relocation brackets. These will give you the best bang for the buck traction. Please be advised that these do need to be welded on to be safe. IF you do not have access to a welder, then I guess just change the lower control arms to spohn tubular ones. You should change the shocks if they are worn out, new shocks will aid in the launch.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
