Problem installing KYB shocks
Old Jun 24, 2002 | 12:07 PM
gta ta's Avatar
Need some advice! I installed some KYB gas-a-just (KG5562)shocks over the weekend. The top nut bottomed out (ran out of threads) before it conpressed the rubbers. It is tight but no compression. I installed the saucer washers and rubbers right but I always thought you were supposed to tighten these down until the rubber was as wide as the saucers. So should I add some washers and tighten down more???
The originals I took off where twice as wide and twice as thick.
Old Jun 24, 2002 | 08:35 PM
KenV's Avatar
Car: A few
Engine: All Eights
Transmission: All kinds
How tight is tight?
Hey.
I run the same shocks on my Formula, and I did not run the nut down as far as you did (looking at the amount of exposed threads in your photo). Close, but not quite. As long as the bushing is not free to move around you should be just fine. It will not look like the factory assembly, that's for sure. I just ran the nut down until I saw some compression of the bushing, and double-nutted the suckers in place. I bet you could do the same just as things are. Ensure that the shock bushings (upper and lower, referring to their relationship to the mounting hole) are seated and let her ride.
HTH, peace
Ken
Old Jun 25, 2002 | 10:02 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
That's the way they get installed. Tighten the nut down untill it bottoms out. That's it finished
Old Jun 25, 2002 | 11:03 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Just like these guys said. I installed mine yesterday and they're the same. It's not the case with these bushings as it is with end links.
Ed
Frozer!!!
Jan 19, 2024 04:55 PM
rocn7roc
Sep 21, 2021 02:16 PM
customblackbird
Aug 15, 2021 10:16 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
