17x11 Wheels on rear
Old Jun 25, 2002 | 04:50 AM
LBSZ28BLOWN's Avatar
Car: Devastating Droptop
Engine: 355 Supercharged
Transmission: Auto 4L60, Built for 700hp
My question is dose anybody know what back spaceing is required to fit (17x11 wheels with 315x35x17 tires) on the rear of a 92 Z28.
I understand that the inner well needs some modification.
Any help would be Greatly appreciated.
Old Jun 27, 2002 | 12:27 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
It depends on how much you want the wheel to stick out. If you want them to look good then you will need to modify the LCA less than if you have them stick out a little. Are these new rims what you can specify the backspacing on?
check out ws6.com he had his stock wheels widened so some modifications were needed. I don't know if he moved the rim out a little though.
Old Jul 3, 2002 | 03:46 PM
irocdan's Avatar
Car: 88 Iroc vert
Engine: 305 tpi. cts-v brakes
Transmission: Tremec T-56
which wheels are you wanting to use?
Old Jul 3, 2002 | 03:47 PM
irocdan's Avatar
Car: 88 Iroc vert
Old Jul 3, 2002 | 05:51 PM
Omega's Avatar
Engine: LS1 / LS3
Irocdan:
Do you have any trouble with your front rims scraping your inner fender well? It looks like you have had to do some serious trimming. Did you raise your bump stops?
Old Jul 4, 2002 | 03:29 PM
Yep,
I whant to use the SLP ZR1 style Camaro SS wheels 17X11 on the rear and I'll keep My 17X9's on the front.
TPIS Also has the wheels, they have too different backspacings on their 17X11 wheels, 36mm & 50mm.
I guess I'll go with the 36mm and add an addapter as nessasarry, unless the 50mm will bolt on and not stick out to far.
Old Jul 5, 2002 | 08:54 AM
irocdan's Avatar
Car: 88 Iroc vert
omega,no i dont scrape my inner fender wells and havent messed with the bump stops either.but if i hit a dip like on the freeway going at a decent speed,i'll rub a bit on the outermost plastic wheel well just inside of the fender lips.
Old Jul 5, 2002 | 09:02 AM
irocdan's Avatar
Car: 88 Iroc vert
lbsz28,i suggest getting the 50mm,you'll won't need as big of an adapter.i have the 50mm which is the grand sport offset,and i needed the 1 1/4" adapter.i hope this info will help you out.
Old Jul 5, 2002 | 07:41 PM
irocdan,
Thanks for the Info It's greatly appreciated.
Vintageracer
Jan 10, 2020 05:33 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
kah992
Aug 19, 2015 02:55 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
