Sticky Brakes
Old Jun 25, 2002 | 04:15 PM
Justin Moore's Avatar
Car: 1986 Z28
Sticky Brakes
When I jack up the front of the car and spin both front tires by hand the front left seems to spin normally, about 2-3 times before it comes to a stop. The right front wheel only spins about 3/4 of a turn before it comes to a stop. It seems like the right front caliper is always on, but just a little. What could be causing this, the brake hose or the caliper?
Old Jun 25, 2002 | 06:47 PM
AFrikinGoodTime's Avatar
your brake rotor is probably warped. Its like spinning a bicycle wheel that is slightly bent, it will spin around a bit but stops when the bent part hits the brake pad.
Or your wheel bearing nut is too tight.
dbrochard
Sep 19, 2015 08:13 PM
Randomtask2
Sep 7, 2015 05:06 PM
Stryker412
Sep 7, 2015 09:11 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
