What are the biggest sway bars?
Old Jun 27, 2002 | 10:41 PM
Terry Kennedy's Avatar
Car: 88 IROC
Transmission: pg
Axle/Gears: 9" w/3.89
What's the biggest that are made for our car's stock or aftermarket and which are best hollow or solid?
Old Jun 28, 2002 | 12:12 AM
urbman's Avatar
36mm front -hollow
24mm rear - solid
The "best" is what is best for your chassis setup,
purpose, and driving style....
Think of sway bars as a tuning element ...
similar to changing VE tables for an engine
The "best" is what your current setup requires
once you change your setup it is less likely to be best...
Old Jun 28, 2002 | 02:21 AM
AFrikinGoodTime's Avatar
BMR claims to sell a 32mm solid Front swaybar that is 40% stiffer than the 36mm hollow 1LE front bar.
Maybe on a V6, But definately not a V8 Camaro. They are notorious for understeer and this would make it worse.
A balanced set of bars front to rear will set a car into a 4-wheel drift.(other varibles also, but for now lets stick to what bars do)
If the front bar is stiffer in proportion to the rear- the front inside tire will "lift" and cause the car to push.
If the rear bar is stiffer in proportion to the front-the rear inside tire will "lift" and cause the car to be loose.(backend slide sooner than the front)
A proportioned set for a V8 is 36mm hollow front/ 24mm solid rear. This is as big as needed even for racing.
Old Jun 28, 2002 | 06:18 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Should anyone be interested in the 36/24mm set up, please see my ad in the classifieds.
JamesC
Old Jun 29, 2002 | 12:20 AM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
What do WS6 cars come with? Mine has the WS6 performance suspension and I wanted to know.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
