skinny/wide selections?
Old Jul 1, 2002 | 02:51 PM
88ROC1LE's Avatar
I was wondering what tire sizes some of you are using if you have the skinny/wide setup? I am looking for a skinnier size to put up front now that I have no powersteering, but I want to be careful not to put to small of a tire. I have the 16" stock IROC wheel, but I am looking to maybe switch wheels if the $$$ is decent. Please help me decide, thanks guys!
Old Jul 2, 2002 | 11:12 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
If you still want to turn fairly ez, then put real skinnies up front. A 225 is HARD to turn w/o power steering. I'd go w/ a 3-5" racing tire.
Old Jul 2, 2002 | 03:18 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I run 205/70R15 Michelins on 15x6 front & 275/50R15 DR's on 15x8 rear. I got the Michelins from a 2001 Caravan that was totalled for $10 ea. They are almost new.
Old Jul 2, 2002 | 06:42 PM
88ROC1LE's Avatar
thanks, just so you guys know I have been driving on the 225's for about 2 weeks, my forearms have gained almost 1 1/2 in diameter!
Old Jul 8, 2002 | 01:16 PM
EDDIETA_ZZ3's Avatar
Car: Trans Am
Engine: ZZ3 HO
Transmission: 700R-4
Are you using the F-b ody pitman arm for the manual steering box?
The S-10 pitman arm is not as long and will make it harder to turn the wheel (Less leverage)
My steering is not bad for turing p235 60 r15's in the front and I'm a small guy.
Ed
Old Jul 8, 2002 | 06:45 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
15x3 rim and p165r15 turns easy with manual steering
Old Jul 8, 2002 | 07:00 PM
Tas's Avatar
Tas
Ooo get these
www.centerlinewheels.com
xbmx89
South Central Region
Oct 31, 2015 10:59 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:13 PM
Mdenz3
Sep 17, 2015 08:36 AM
