LCA relocation brackets
Old Jul 4, 2002 | 08:11 PM
logikal6785's Avatar
i'm looking at replacing my LCA's and putting on eibach sportline springs with kyb gr2's ... since the car will be lower how necessary will the LCA relocation brackets be ? and how much of a pita will they be to install =D ?
Old Jul 5, 2002 | 04:23 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Installation is easy and worth the time since you are putting all that other stuff in. I'm not sure if the relocation brackets can be bolted on (all my stuff is welded).
You can buy the brackets for about $50, probably less. With the right equipment you can make your own.
Old Jul 5, 2002 | 05:59 AM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
You'll want the LCA re-location brackets if you're lowering the car.
Spohn makes some nice weld-in brackets. I needed the bolt-ins, as I have two differently geared rears.
Both work.
Old Jul 5, 2002 | 10:57 AM
thx guys
Old Jul 7, 2002 | 09:57 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Both work.
where can you get bolt in ones, and can they be welded in after they are bolted in?
Old Jul 7, 2002 | 09:59 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
Does anyone have the dementions I would like to make my own.
Thanks, Kory
Old Jul 8, 2002 | 03:56 PM
Pukka's Avatar
Check the major racing store (jegs, summit, etc) and just ask for em.
Yes you can weld "bolt on's". In fact, this method is preferred.
Old Jul 9, 2002 | 05:18 AM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
if you're lowerng the car and don't want increased wheel spin and/or tire hop, get them.
Spohn has weld in, and BMR Fabrications has weld in and bolt in, and you can weld the bolt in units. Welded will be much more secure.
BMR Fabrications brackets
Spohns brackets
Old Jul 10, 2002 | 01:13 AM
5 litre eater's Avatar
Car: '84 Trans Am
Engine: 350ci Sportsman heads, B&M blower
Transmission: Turbo 350
Measurements would be great!I'd love to make my own
Old Jul 10, 2002 | 09:05 AM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
the weld-in brkts are only about 60 bux. Then you pay to weld them in. For me that would be times 2.
BMR makes bolt-in brkts for about 100 bux. One cost, used for both.
Old Jul 10, 2002 | 09:07 AM
Inwo's Avatar
Car: 2007 Saturn Sky Redline
Engine: 2.0 turbo
Transmission: m5
Axle/Gears: 3.91 LSD
The Spohn ones are of unbelievably high quality. I highly recommend them. It's real cheap to get them welded on too, $25 job at any muffler shop.
Old Jul 10, 2002 | 09:18 AM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Steve does make quality stuff. That is why I went to his shop to get his SFC's welded in. I also got his (center)adj LCA's. I got them with poly on bothends, but later, when I wanted 'rod' on one end, he made just the one end for me on order.
But the weld-in LCA brkts, that's 65 per, plus welding @ 25 per, that's 180 for the two differentials. Compared to the 110 for the bolt-in brkt.
It's a matter of budget. I am currently having to pull the 350 to find out why it lost oil pressure at the track a few week-ends ago.
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
armybyrd
Sep 26, 2015 03:37 PM
