How hard to add rear sway bar?
Old Jul 9, 2002 | 02:52 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
My 83 firebird does not have a rear sway bar on it, and from what I understand, it did not come with one from the factory since its not a T/A. I found an IROC in the junk yard with front and rear sway bars on it, how hard would it be to add the rear sway bar to my car? Is there anywhere I can just buy polyurethane bushings for IROC sway bars?
Old Jul 9, 2002 | 04:58 AM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
It's pretty easy to install a rear bar. You probably should also get the front bar off of the same car you get the rear bar from, or at least compare front bar sizes, and if the other cars bar is bigger than yours get it too. You can get poly swaybar bushings and endlinks from Jegs.
Old Jul 12, 2002 | 11:54 PM
Bunker82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TH-350
It's really easy. Just remember to get all the brackets and bolts. On my site I wrote alittle about installing it. The hardest part is tapping the holes in the frame, but no biggie.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
z28addict8490
Aug 7, 2015 08:48 PM
