50/50 Braking and loose steering box info needed.
Old Jul 9, 2002 | 05:00 PM
SLZ's Avatar
SLZ
Is there any way to tighten up the steering box so the car dosent wander(all new front suspension components installed) and to take the slack out of the wheel(loose steering). This is an 89 Formula 350 w/WS6. Also, there was a guy who modded something in the silver block that the brake lines go into at the brake booster. He was able to make the front(that brakes most)and rear(that brake least)brakes work 50/50. Just wondering if anyone had info or any other info along the lines of 50/50 braking. Thanks, STEVE Z
Old Jul 9, 2002 | 05:23 PM
urbman's Avatar
Just a guess ...
I imagine he modified the spring tension in the proportioning
valve...
Old Jul 9, 2002 | 05:50 PM
PonchoTA's Avatar
It may not be the steering box. Have the ragjoint checked. Probably needs replacing too. That tightened mine up considerably.
Old Jul 9, 2002 | 06:05 PM
SLZ's Avatar
SLZ
Whats a ragjoint? Sounds interesting to say the least. Thanks, STEVE Z
Old Jul 9, 2002 | 08:40 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Brake balance on our cars should be set at around a 70/30 ratio I believe.
Thanx,ANDYZ28
Old Jul 10, 2002 | 06:47 AM
scauffiel's Avatar
Check this thread: https://www.thirdgen.org/techbb2/sho...highlight=bias for info on the brake bias thing - my pix no longer show up because I moved websites however. If you need them, let me know and I can post them again. I wouldn't say it's 50/50 though, more like 60/40'ish.
Check this thread: https://www.thirdgen.org/techbb2/sho...hreadid=118027 for info on the steering box stuff. Heed the warning about TOO TIGHT - you will burn up your box. And no one needs a burned box.
Ain't the search function a wonderful thing? (Just busting your nuts)
S.
Old Jul 10, 2002 | 06:38 PM
SLZ's Avatar
SLZ
Thanks Scauffiel for the brake mod info. I knew Ive seen this post before but couldnt remember where. Thanks for the steering info too. STEVE Z
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
Vintageracer
Jan 10, 2020 05:33 PM
MyRedCamaro
Dec 29, 2015 05:16 AM
backtothe80s
Sep 5, 2015 12:39 AM
