noise on turns &brakes has me stumped.. plz help
Old Jul 16, 2002 | 11:23 AM
pvknight's Avatar
I get a high screech from the front wheels on:
1. Light braking (getting on and off the pedal)
2. Turns, any sort, any speed, screeches.
3. Combination of the above two, braking on turns, produces diff high pitch screeches also.
I thought it might be the bearings, but those produce a low 'growl' when going bad. Pads are still good and rotors don't look damaged. The only guess I have left is that the anti-squeel applied on back of pads when changed doesn't work anymore??
Thanks,
Brian
Old Jul 16, 2002 | 03:32 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
What brake pads are you using? PF Carbon Metallic pads have a tendency to squeal.
Usually I pitch the anti-squeal shims and instead apply anti-squeal adhesive made by CRC. It keeps my pads nice and quiet.
Old Jul 16, 2002 | 05:05 PM
pvknight's Avatar
... thing is, I didn't have this problem up to a few weeks ago, it just developed itself, so I don't really think it's anything wrong with the pad seating... a friend of mine mentioned to check the backing plate?
Old Jul 16, 2002 | 06:50 PM
Lounge Lizard 6's Avatar
Sure it's not the wear sensors?
Old Jul 16, 2002 | 10:18 PM
AFrikinGoodTime's Avatar
I second this statement and only ad that I llike to also bevel the leading edge of the pad. This always has prevented brake squeaking for me, and lessen the hard initial bite when softly pedaling the binders.
Old Jul 18, 2002 | 01:33 AM
pvknight's Avatar
Okay okay... It turns out that the wear sensors on the bottom part of the inner driver side pad was hitting... I guess those can scratch even w/o brakes in my case b/c the front pads weren't fully releasing. Turns out that rear drums weren't "self adjusting" and therefore totally ineffective... causing the fronts to burn out much fast + not release. Ahwells, got the parking brake reset and the brakes serviced as well as a suspension check Thanks for the help yall
Old Jul 19, 2002 | 09:18 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
i used to have the same problem w. the drums on one of my older gms. Turns out if you only do mostly light brake applications, they wont adjust. Youll have to make a point of doing several hard stops in like reverse or something like that to get them to adjust or take the drums off and turn theadjuster wheel yourself. If your going to adjust em by the first method, make sure you do it often or the wheel cyl. will get damaged. Found that one out the hard way, too.
theshackle
Sep 17, 2020 08:26 AM
Fronzizzle
Mar 18, 2019 08:29 PM
B_Dubya
Aug 26, 2015 05:09 PM
BrianI
Aug 9, 2015 11:52 AM
