this is stumping me
Old Jul 19, 2002 | 01:19 AM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
this is stumping me
ok i just got done intalling a rearend in my car, but now whenever i go over a bump a noise comes from the back passenger side wheel, it sounds like something is loose, please give any info, im gonna further investigate this tomm, thanks
Old Jul 19, 2002 | 10:16 AM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
Did you put the isolater back on top of the rear coil springs? If not the spring is probably makeing the nosie.
Old Jul 19, 2002 | 11:55 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Probably has to do with the shock or stabilizer bar.
Old Jul 20, 2002 | 05:04 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
If the LCA bolts are not put back on really tight it will cause a noise too.
Old Jul 20, 2002 | 05:14 PM
PonchoTA's Avatar
Remember, most of the rear suspension bolts need to be torqued down with the susp. LOADED, not in the air. That will definitely interfere with the proper torque loading.
Old Jul 27, 2002 | 11:17 PM
Engine: 383, L69
thanks all, it was the lca bolts,
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
djmarch
May 8, 2016 11:32 AM
Quzyle
Oct 15, 2015 03:35 PM
tuningnewb
Sep 23, 2015 07:06 PM
camarohelp
Sep 22, 2015 03:19 PM
