The "ANDYZ28 1LE Plus CD"
Old Aug 1, 2002 | 10:13 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
The "ANDYZ28 1LE Plus CD" is finally ready. It took longer than I expected, but August 1st isn't too bad.
http://www.3rdgensolutions.com/1leupdate.html
or http://www.spohn.net/index.cfm?fusea...&categoryid=48
What do you get?
It contains over 300 annotated Digital Images covering 21 different 3rd generation F body topics.
While the majority of these images are concerning the 1LE brake upgrade, you also get valuable information on rear axle drum-to-disc conversion and important, and previously unpublished information about the "spindle modification", required when doing the 1LE front brake conversion.
Look at the Table of Contents:
1. 1LE front brake conversion
Stock vs 1LE Components
Spindle Modification
Spindle Identification
Parts Required
Assembly
Installation
Combination Valve
Wheel Fitment
Problems
Project Car
Frequently Asked Questions
2. Rear axle drum-to-disc conversion
3. Pre ’89 rear disc brake comparison (Delco-Moraine)
4. Brake lines, early to late style
5. Body integrity
6. Sagging doors
7. Subframe connector installation
8. Spare tire problem
9. Transmission cooler install
10. Converting of A.I.R. pump into an idler pulley
11. TH700R4 install into an `82
12. Audio conversions
13. Steering geometry
14. Conversion to Serpentine belt drive
15. Axle removal & reinstallation
16. Sample RPO tags
17. Mistakes I made
18. S-10 center caps on 16” Z28 wheels
19. The “Wonder Bar”
20. Spring Rate Chart
21. Brake Edge Codes
Thanx,ANDYZ28
Old Aug 1, 2002 | 10:49 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Thank you Sir!!!
Guys, it really takes a lot to put all of this together on your own time, and I'm sure this CD has a TON of info that we all will find useful.
I appreciate it very much, Andy.
Ed
Old Aug 2, 2002 | 12:23 AM
PonchoTA's Avatar
Ditto!!! Well said Ed!
Vintageracer
Jan 10, 2020 05:33 PM
PurelyPMD
May 5, 2016 04:57 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
mcgarnicle
Sep 24, 2015 07:18 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
