clunking noise help
Car: Camaro Z28
Transmission: auto
clunking noise help
there is a very weird noise coming from my car.. when i drive straight it's fine, but if i turn the wheel left or right a half a turn or more, there is a banging noise and i feel it in the steering.. anyone have ANY idea what the hell it is, remember i don't feel or hear anything when i'm driving straight only turning
is it to the extreme limits?? i noticed a noise when my i turned the wheel all the way..i got it on a lift and looked around....all looked fine. then i noticed that somethign was hitting my frame...sorry i forgot what exactly it was, it was over a year ago. hope this helps
Car: 92 RS Convertable
Engine: RAMJET 350
Transmission: G-FORCE T-5
clunk
Have you checked every component (ie joint) in your front suspension?
tie rod ends center link idler arm pitman arm lower ball joints?
jack the front end up and put it on jack stands with the wheels off the ground push and pull on the tires and look for a loose joint (tie rod ends center link ball joints ect) then try to push up and down on your idler arm
let us know if you find the problem
Ryan
Ryan
sjorgens
Oct 1, 2015 07:54 PM
luvofjah
Sep 26, 2015 08:28 PM
