question about wheels
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
They will fit just fine. But if you call weld they can tell you if they have the correct "backspacing".
Thanx,ANDYZ28
Thanx,ANDYZ28
5 1/2" backspacing is a lot. I have Weld imitation 5 stars with 5 1/4" backspace with Nitto 275/50/15 Drag Radials. If I corner hard while jumping on the gas they rub just a touch. With 5 1/2" backspacing you will probably need to run spacers.
