Another 1LE question... pics inside
Old Aug 15, 2002 | 08:54 AM
pianiy's Avatar
Ok, I finally got my rotors yesterday and the pads came in a few days ago, I put a set up against the rotor surface and there's about 1/2" above and below the pad yet... this seems odd as there would be uneven wear across the rotor surface and it'll eventually develop ruts. Should the pads be wider?
And any idea which side the rotors go on? (they're slotted) I'm guessing, the one on the left is the left side, right-right side.
http://web.njit.edu/~ljd8271/Temp/1LE/1LE%20parts.jpg
http://web.njit.edu/~ljd8271/Temp/1LE/1LE%20pads.jpg
Old Aug 15, 2002 | 01:34 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
You seem to be right...left rotor=driver's side, right=pass. All slotted rotors I've ever seen have the slots spinning that way. I wouldn't worry about the pad issue. Unless they're ROCK hard, they'll wear out before the rotor does. You'll be happy with the setup.
Ed
Old Aug 15, 2002 | 07:48 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
pianiy, You have my "ANDYZ28 1LE Plus CD". The picures in the assembly section are exactly how a stock 1LE front brake setup should appear.
Keeping that in mind, something doesn't sound right.
Thanx,ANDYZ28
Old Aug 15, 2002 | 07:52 PM
ANDYZ28's Avatar
Car: 1982 Z-28
I do not know the dimensions of the pads in your picture. But they appear to be the wrong pads entirely.
Thanx,ANDYZ28
Hotrodboba400
Dec 10, 2019 07:07 PM
Lanz06
Mar 13, 2019 06:07 PM
64Chief
Sep 12, 2015 08:05 AM
gt4373
Sep 9, 2015 10:29 AM
lakeffect2
Sep 7, 2015 03:52 PM
