Car pulls to left when i stop?
Old Aug 19, 2002 | 06:18 PM
Camero90tbiRS's Avatar
When i push the brakes the car pulls hard to the left. I was thinking that i overtightin the caliper but im not sure. I just rebuilt the right caliper and the left one look ok. So what can the problem be? This happened after i put the new power booster, master cylinder, and brake pads in.
Old Aug 19, 2002 | 07:41 PM
mechanicalmehem's Avatar
one possible solution would be if you let the right caliper hang by the hose it might have collapsed internally, which happens quite often(even if you didnt, it is still quite possible) that would be the first thing that I replaced. What I believe is happening is that the left caliper is working correctly and that the right caliper is not compressing to hold the pads against the rotor.
Just my 2 cents but usually,with a pull similair to this, start by replacing the hose opposite the direction the car pulls.
Old Aug 19, 2002 | 08:14 PM
THANKS, WHEN REBUILDING THE CALIPER TO YOU HAVE TO FILL THE CALIPER WITH FLUID BEFORE RE INSTALLING THE PISTON AND SEALS?
Old Aug 19, 2002 | 11:21 PM
it should bleed out just like any other brake bleeding, just make sure you dont let any air back up into the hose.(usually drames out so that shouldnt be a prob, just make sure reservoir is full.)
Old Aug 19, 2002 | 11:33 PM
thanks for the response
Old Aug 20, 2002 | 05:08 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I agree with mechanicalmehem.. the right hose sounds like the culprit. Don't let the m/c run dry!!! If both brake hoses are the original 1990 factory ones, you should replace them both- they're 12 years old. Be safe.
Old Aug 21, 2002 | 12:55 AM
jizzyz28's Avatar
CHECK OUT THE ROTORS THEY MIGHT NEED TO BE REPLACED OR CUT. CHECK YOUR SWAY BAR AND THE TIE ROD ENDS. THE HOSES AND CALIPER PROBLEMS SOUND GOOD ALSO, BUT WHILE YOUR DOWN THERE CHECK ALL OF YOUR SUSPENSION
Old Aug 21, 2002 | 08:09 PM
not a problem helping, hey jizzy, could you lose the caps, please?
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
TheExaminer
Aug 26, 2015 04:59 PM
hokis
Aug 9, 2015 03:57 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
