New front Rotor problem
Old Aug 25, 2002 | 12:58 AM
Vicious 88 GTA's Avatar
I got a new passenger side front rotor and along with it I got the front brake pads for my 88 GTA L98 5.7...well I take it to my mechanic and on the way home about a block away from my house I step on the brakes and it pulls hard to the right, so I let off and it was still pullin, so I drove to my house and I could smell the pad burning like hot....so I go and see and it and it is hot as hell.....so what could be the problem, the pressure seems fine and so i went out for another drive and it didn't do it, so I drove back from my Gf's house and it did it again, I don't know what could be wrong, can you all help and give me some prices if you can, any help will be appreciated.....AARON
Old Aug 25, 2002 | 01:32 AM
ede's Avatar
ede
the bushings the caliper bolts go through aren't moving, or other wise stuck, or the caliper is stuck. take it off and have a look.
Old Aug 25, 2002 | 09:12 PM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
so, you only replaced one rotor not both. one side has a new rotor/pads and the other is old rotor/pads that is worn? I've always heard when replacing one, replace the other, so things can be equal.
Old Aug 26, 2002 | 10:08 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Could be a few different things, but I suspect that the condition you are having is related to having different rotor surface conditions from one side to the other.... the one that is new will have a different friction coefficient than the one that has been run on the car previously. This is why most people just get both sides at the same time or resurface both at the same time.....
You may have a problem with the brake hoses as well. They are an extremely common problem on our cars. It is probably not the case this time, but sometimes the hoses are on their way out and anything can put them over the edge - like the fluid movement during the compression of the piston back into the caliper and reapplication of pressure when reinstalled. What happens is that the rubber wears out and the hoses will collapse on themselves during operation causing the calipers to stick or have a delay in application which creates a pulling condition.
Ede mentioned caliper slides and they could be the cause as well so check them out as well.
Good Luck
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
