Are subframe connectors cost big $$ so is there a way to make my own?
Are subframe connectors supposed to cost 500 canadian??? That seems like way to much to spend but I called 3 different places and the cheapest store sold them for $465 plus another 100 to install. I cant spend that much on them so is there a way to make my own??
thanks Jesse
thanks Jesse
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
Yea its possible to make your own SFC a few people on this board have done it. They'll probably see this and post up. As for being expensive how much is that in US dollars? Cause I bought my SFC's for $175 and shipped to hawaii came out to a total of only $225. Is the canadian to us dollar ratio that bad?
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
They were easy to make and cost me about 50 bucks in material.
I used 2" square tubing .187 wall. and some 1 1/2" .120 wall that I had laying around. It tightened up the car alot.
Kory
Kory
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
Yea make your own, or go to a welding shop and get them to make you a set if you don't have the equipment.
you will still save a couple hundred bucks getting a welding shop to do it.
well heck if it is that cheap to do then i might do it as well!! gotta question though. if i do it im gonna do the bolt in kind for now (till i get to school and can weld it) any thing i would need to do to keep it stronger?
ambainb
Apr 25, 2016 09:21 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
