Which sway bars are better?
Old Sep 1, 2002 | 12:57 AM
MotorCityMuscle's Avatar
Which would be better for a front sway bar- one form an 84 Z-28 or an 83 Trans Am?
Anmd for the rear-stock 83 Trans Am or 86 IROC w/ rear disk brakes?
BTW, the 83 TA has rear drums.
Old Sep 1, 2002 | 03:05 AM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
The best factory sway bars would be the 36mm front and 24mm rear found on the WS6 equipped Firebirds and equivalent IROC's.
Old Sep 1, 2002 | 03:33 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
The early thirdgens didn't have really big bars. Try 86-92 for 36mm/24mm bars.
Old Sep 8, 2002 | 04:22 PM
87 Firebird's Avatar
Actually, the best front sway bar was the 34 mm SOLID bar, not to be confused witht he 34 mm hollow bar. This bar was found on some T/A's, but I don't remember exactly what year they were. If y you find 34 bar in a wrecker's, yank it out and drop it on the ground, if it really vibrates, it's likely the hollow bar. If it seems REALLY heavy for it's size, it just might be the 34 Solid.
Old Sep 10, 2002 | 11:09 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The 36 mm/24 mm combo was found on some 89-92 Camaros and some 86-92 Firebirds. Should you go with this combo, I highly recommend Lon Salgren's greaseable 36mm bushings (modified Guldstrands) along with the greaseable ES version (15/16).
JamesC
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
