Do wheel spacer/adapters affect strength
Old Sep 7, 2002 | 09:24 PM
91-ZZ4-Z28's Avatar
Do wheel spacer/adapters affect strength of front suspension?
I have a 4th gen rear with 4th gen wheels and I will need 2in spacer/adapters for the front and I worry about the strength of the hub.
Old Sep 8, 2002 | 10:36 PM
RallyRedTexan's Avatar
Car: 92 RS
Engine: 5.0 TBI
Transmission: A4
I'm new here but, I'm on alot of other boards.
Generally it's only a real concern once the spacers become old and worn(like anything else), or if on the rear, if you put down serious power.
Old Sep 13, 2002 | 08:38 PM
PhilM's Avatar
Car: Accepting applications...
I have heard the solid aluminum spacers are great, but it is the SPINDLE you have to worry about. You are moving the wheel out from the hub, and this is essentially moving the point on the spindle that holds the weight.
does that make sense?
Old Sep 15, 2002 | 03:43 PM
Marc 85Z28's Avatar
That's only true when moving the wheel's centerline away from the spindle. When the backspacing on the wheel's hub is greater, the spacer just takes up the greater backspacing. The wheel centerline moved out only 1/2" on my car. The spacers are every bit as strong as an aluminum wheel. The only problem you could run into is 5 more lugnuts with incorrect torque specs.
Old Sep 15, 2002 | 09:44 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
That's what happened to me! When i first installed the ss wheels they were wobbly b/c i failed to get them tight enough! I just went out and got an air gun to hook up to my compressor and i haven't had a problem since. I am still curious though, my new motor should be putting close to 400lbs/ft and hp to the wheels, should i stick with the spacers or no? What if i were to go with a supercharger in the future? thanks
Old Sep 22, 2002 | 05:13 PM
Marc 85Z28's Avatar
Goto www.skulte.com and check out his IROC. He runs spacers on his car, and is making a ton of power.
Old Sep 22, 2002 | 08:03 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Thanks Marc, that is where i got the spacers from. I'll just have to call Andris up when i get the motor in the car and running!
Fionnla
Wheels and Tires
Sep 11, 2015 11:07 PM
64goatman
Sep 9, 2015 01:09 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
SG91camaro
Sep 5, 2015 10:27 PM
