87 9 bolt rear brakes....
Old Sep 8, 2002 | 08:41 PM
camaro6spd's Avatar
....my rear brakes....87 9 bolt disc rear, rattle...is there ne way to stop that? Am i missing some clips or something.
Old Sep 9, 2002 | 08:50 AM
Nasty_Bird_'90's Avatar
I think your problem is that the brake pads are rattling against the rotors. I dont think i noticed any clips to hold them in place when i did mine, but you may want to look over everything to make sure all is tight. Try tightening the slide pins. If they're a little loose,they may cause the pads to rattle a bit. Other than that, its just a good idea to look everything over a few times. Hope this helps!
Old Sep 9, 2002 | 04:51 PM
camaro6spd's Avatar
thanks i will look into what you have given me so far......ne one have a parts diagram?
Old Sep 13, 2002 | 03:55 PM
Bunker82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TH-350
This is probably not your issue but might be of benefit to the archives. I found when I recently swaped in a 9 bolt disc rear that the caliper slide bolts vary between two styles. One looks like a typical bolt, and the other is necked down (has a smaller diameter at the end). But anyway the end bushings in the caliper vary to correspond. The bolts that originaly came with my rear I yanked out of the junkyard had the necked down style. But when I got a pair of rebuilt calipers they had the bushings for the first style. I didn't realize it till I was putting on the calipers and saw alot of daylight between that bolt and the bushing. I allowed me to rock the caliper by hand. I tried to get bushings for the necked down style and no one had them. Not even the dealer. So I figured I have to get the non-necked down bolt. New they were $25 a PIECE! Freakin' Pep Boys. Yeah not gonna drop $100 on bolts. Luckily I went to the junkyard and found out that the front slider bolts are the same and so I slapped them in there and all is hunky dory.
Oh on those clips I had a devil of a time finding two at the junkyard. Looked like most people has just put some anit squeak goo on the back and that was supposed to hold it I guess. Seemed too mickey mouse for me. I prefer clips.
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
1nastygta
Aug 8, 2015 07:38 PM
