9 bolt brake bracket questions
Old Sep 9, 2002 | 08:38 AM
foney_email's Avatar
Car: 97 200sx se-r, 82 Trans/Am
Engine: 350 bored to 355
Axle/Gears: 9 bolt 3.45
I am buying a 9 bolt, it has the dust covers for the rear disk brakes but I don't know if it has the caliper brackets. Will the caliper brackets from my current rear (a ten bolt with rear discs from an 82) fit the bw 9 bolt?
I need to install this immediately. I don't have time to buy the le1 brake brackets or anything else.
in summation: Do the rear caliper brackets from an 82 ten bolt fit the axles to an 89 nine bolt?
I hope this isn't confusing.
Old Sep 9, 2002 | 09:06 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
No, 9-bolt brackets are designed to retain the axle. I'm pretty sure 10-bolt brackets won't work.
Old Sep 9, 2002 | 11:22 AM
So, any suggestions on what I should do.
Should I buy the le1 brackets to hold my calipers.
I think I need to take a look at the 9 bolt again.
Old Sep 9, 2002 | 02:46 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Here's what you need on Ebay.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1857295584
Then get the PBR brake setup for the rear. Otherwise, you'd need to modify some 10 bolt ones or weld them on.
Ed
Old Sep 9, 2002 | 04:19 PM
Yeah! I have that part on there. (the one listed on ebay) So I guess that since that option was only availible for 89 and this is an 89 9 bolt, that I need to buy some PBR's.
What is the benefit of the PBR's?? (besides being all shiny and looking bad @ss)
how much are they??
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Eric-86sc
Apr 3, 2016 03:52 PM
red90IROCls1
Aug 25, 2015 06:56 AM
redmaroz
Aug 16, 2015 11:40 PM
