What does the electrical connection on the steering box do?
Old Sep 9, 2002 | 03:45 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
There is a two prong connector going to a solenoid/ sensor lookin thing on one of the lines going into my steering box, does anyone know what that does, or what it goes to? Mine's just sitting there, not connected to anything... This is on an 86 Z28, originally an LG4 car if that matters...
Thanks for the help...
Eric
Old Sep 9, 2002 | 04:08 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I asked this same question when I swapped my motor out and it hooked up to the ecm and when the wheel was at full lock, it would increase engine rpm so as not to bog down the engine and kill it.
Old Sep 9, 2002 | 04:26 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
oh i see. Well being that i don't have an ECM anymore.... snip snip...
thanks man
Old Sep 9, 2002 | 04:38 PM
IHI's Avatar
IHI
OOOOH YEAH baby, when I pulled out the 305, side cutters were my BEST friend. SOOO much more room in there now and not all the mumbo jumbo.
Old Sep 9, 2002 | 11:25 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
As I recall it bumps the idle speed when the steering is moved from the center "dead spot". Since this is when the power steering would be working it is compensating the idle to manitain the rpm's. I love it, when you don't know what something is for, you bypass or defeat it. LOL
Lon
Old Sep 10, 2002 | 07:18 AM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
problem is with my car, that 90% of the electrical connections in the engine bay are now useless, because my ECM is long gone. So crap like that wasn't doing any good anyway. I'll take a pic of all the garbage i've removed from this thing when i get back from class. You'll be amazed...
Eric
Old Sep 10, 2002 | 11:43 AM
IHI's Avatar
IHI
Better use the panoramic veiw!!
Old Sep 10, 2002 | 12:37 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
see what i'm talking about?
Attached Thumbnails What does the electrical connection on the steering box do?-pic2.jpg
Old Sep 10, 2002 | 12:39 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
heres what the engine looks like now, i'm nowhere near done, but i'm in the middle of a head swap right now, so the rest will be coming our soon....
Eric
Old Sep 10, 2002 | 12:40 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
suppose a pic would help, don't know why it came out so blurry, but you get the idea...
Attached Thumbnails What does the electrical connection on the steering box do?-pic1.jpg
Old Sep 10, 2002 | 01:37 PM
pianiy's Avatar
Its a pressure sensor and like lonsal said it raises the idle to compensate.
Old Sep 11, 2002 | 05:00 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
zupman, I had a similar pile of parts left over when I did my V6 to V8 swap. The only drawback is that my "check engine soon" light has been on for seven years.
Every time I check- it's still there.
Old Sep 12, 2002 | 09:32 AM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
LOL!!!!
why don't you just pull the bulb?
BRoss99
Aug 10, 2025 05:08 PM
Amillionoh7
May 24, 2020 08:01 AM
MyRedCamaro
Dec 29, 2015 05:16 AM
backtothe80s
Sep 5, 2015 12:39 AM
zayne0
Aug 24, 2015 07:22 PM
