Wheel Weights
Old Sep 13, 2002 | 05:56 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Wheel Weights
SLP Firehawk rims. When I get them balanced I don't want to have the wheel weights on the outside making a mess out of the rim.
Problem is that any time I've had the weights put on the back side of my old rims the wheel has always been a little bit out of balance so I just ended up putting the weights back on the outside of the rim and it was OK after that although marked up because of the weights.
So how can I get around this with the new rims:
1. Should they balance properly with the weights on the back notwithstanding the problems I've had with this before.
2. What should the lug nuts be tightened to on the SLP aluminum rims.
Old Sep 13, 2002 | 06:25 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
if you only balance using the static set up ( only weight on the inside lip), then most of the time you'll have a little vibration. what you can do is have it balanced by having the weight on the inside lip and sticky weight on the inside edge of the wheel closest to the outer side. this is the next best way to balance.
tighten the lugnuts to 85 ft/lbs
Old Sep 15, 2002 | 11:16 PM
RadarRunner's Avatar
Car: 1987 Z28
Engine: LG-4 305
Transmission: 5-speed
I noticed they had put stick on weights on the inside of the back of the wheels facing up toward the rotors on my new wheels.
By the way, I though it was 80 ft/lbs?!?!
Old Sep 15, 2002 | 11:35 PM
mrr23's Avatar
Engine: 360 HSR
it's not the wheel you are torquing. it's the lugnut/stud. for 12mm x 1.5 studs you can use 80-110lbs. on my '94z28, in the owner's manual, it said torque lugnuts to 110lbs
Old Sep 16, 2002 | 09:12 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
https://www.thirdgen.org/techbb2/sho...=wheel+weights
There is a product you can use to balance the tire dynamically from the inside. I posted this info on it before.
Lon
J-money
Jan 4, 2019 09:45 AM
roysatikas
Sep 7, 2015 08:08 PM
SG91camaro
Sep 5, 2015 10:27 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
