HELP: I cant get my weels off!
Old Sep 18, 2002 | 07:21 PM
David Wells's Avatar
Sorry, I know this seems really stupid. I am a new Camaro owner, 86 Berlinetta, It needs new front pads. With the wheel nuts off, The wheel seems securely stuck on the hub. I loosened the nuts and drove around a bit, hoping that the wheel might pop free. No luck. What the heck is the trick? This car was parked for years, I am assuming that the aluminum wheels have sort of gooed onto the hubs. Any suggestions, Please?
David
Old Sep 18, 2002 | 07:37 PM
Steve86TA's Avatar
Car: To many to list
Put a block of wood against the inside of the wheel and hit it with a hammer or sledge.It can be a PITA sometimes.
Old Sep 18, 2002 | 08:59 PM
87transam5.7tpi's Avatar
ya put some wood behind it and beat it w/ a sludge hammer. I wouldn't drive around with the wheels loosened though. that isn't the best idea IMO.
Old Sep 21, 2002 | 09:06 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
You can also go back to your original method of loosening the nuts and driving around to remove them. But this time lay out some 2 x 4's with a gap between them and drive over them.
Lon
Old Sep 21, 2002 | 11:58 AM
87 & Lon, thanks for the help. I was reluctant to beat on the rims. I backed off the wheel nuts a bit, and drove a hundred feet or so doing tight turns, forward and back. You could hear the poing when the rims broke loose. They had a "weld" of aluminum corrosion holding them onto the hubs.
Thanks again for you advice. Now to get the rear wheels off.
David
Old Sep 21, 2002 | 09:23 PM
RadarRunner's Avatar
Car: 1987 Z28
Engine: LG-4 305
Transmission: 5-speed
David
With the car up & lug nuts off, try spraying some pentrant in that general area & then letting it sit a while. Also, rather than a regular sledge hammer, use a hard rubber mallet (less chance of damage if you miss).
If the wheels come loose while the weight of the car is one it you might have problems with lug nut threads, or damage to the wheel.
boussole
Brakes
Jan 25, 2006 05:50 PM
Ezra
Feb 21, 2005 09:55 PM
92BlAcK_RSLO3
Dec 4, 2002 06:13 PM
