What steps can I take to solve a bump steer problem after lowering??
Old Oct 2, 2002 | 02:16 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
I'm looking at installing the Eibach Sportlines what steps should I take to solve the bump steer problem I will develop after doing so? Will I need a different pitman arm and idler arm or will the baer adjustable outter tie rod ends do the job?
Old Oct 2, 2002 | 04:00 PM
chacane67's Avatar
The adjustable outer tie-rod ends should do the trick.
Old Oct 2, 2002 | 04:41 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Have you actually used these adjustable outter tie rods or are you making a wild guess here?? I'm looking for actual knowledge on the matter from people who have had experience dealing with the problem
Old Oct 2, 2002 | 04:57 PM
Bunker82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TH-350
I'd like to know the answer for this one too. I have the same springs.
Old Oct 2, 2002 | 05:40 PM
chacane67's Avatar
Well, I have used this type of device since about.....1989.....
They work very well. Just pay attention to the quality of the rod end itself. Baer uses quality parts, as most of the cars they build parts for they have raced competitively. Which would build my confidence in a product that I didnt know much about. But they do work quite well.
I would recommend that you find a 'Seals-it' dealer to buy the rodend seals to keep out the dirt and elements though.
-edit-
Just to let you know, I used to work for Dick Guldstrand, Roger Penske, PPI and have built cars for John Lingenfelter, Reeves Callaway and Doug Rippie. So my experience should give you the impression of dealing with all the parts you have now and havent purchased yet.
Old Oct 3, 2002 | 01:16 AM
AFrikanGoodTime's Avatar
A good set of roadrace struts will help also. Any time you add a stiffer spring you should marry that with a higher dampening shock to counter act the greater force of the spring. Stock shocks still used in combination with stiffer springs can bounce you all over the road. Dong,Dong,Dong.......I'm sure you've seen a car do that. Its fun to watch.
Oh yeah, I also know Dick Guldstrand and solo raced in the GRA Chacane, I bet we know eachother by face, Hell we've probably talked in person several times.
Old Oct 3, 2002 | 05:18 PM
chacane67's Avatar
Good posibility!!! When were you cone killing with GRA?
Old Oct 3, 2002 | 05:50 PM
Mainly about 7-10 years ago, We have the "Killer '68 vette" Its light blue. I stopped doing it because it just got boring sometimes and took up to much time from my then new family addition. My father an one of my older brothers(I have 5) are usually over at guldstrands at least everyother month or so. My father has known Dick for 40+ years. Matter of fact here a pic (from '94-notice reg. tag on lic. plate):
Attached Thumbnails What steps can I take to solve a bump steer problem after lowering??-vette1-001.jpg
Old Oct 4, 2002 | 08:44 PM
chacane67's Avatar
Ya know, we probally have shared each others company.....
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
backtothe80s
Sep 5, 2015 12:39 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
