Competition Engineering SFCs
Old Oct 12, 2002 | 07:59 AM
86IROC350NY's Avatar
I bought the bolt in kind. Are they worth it, or should i switch to Jegs SFCs. they seemed a little steep at 245, and i am pissed that i will ahve to weld them anyways to have them work right.
--Dan
Old Oct 12, 2002 | 11:42 AM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I sent mine back and got the Southside Machine SFC's. They are much better in my opinion.
Old Oct 12, 2002 | 04:21 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
I have the bolt in Comp. Eng. ones in and I think they work great. I changed the piece from the sill to the center member to a flat piece of metal. You can now bolt them in to the floor. I didnt find the need to do that. They would be easy to weld in if you want. Good thing about the way I did them is that there is no loss of ground clearance and they dont interfere with the exhaust.
Old Oct 14, 2002 | 08:42 AM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
yankee, could you get a pic to show what you're referring to?
Old Oct 14, 2002 | 09:31 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It is not possible to make bolt-in ones work right. There's way too much stress and movement there, sooner or later the bolt holes will elongate. Do not bother trying to find ones that will work by just bolting in, they don't exist.
If you get "bolt-in" ones from anyone, bolt them in, then go get them welded. Consider the bolt-in function as merely a convenience for the DIYer as a prep to welding.
Frozer!!!
Jan 19, 2024 04:55 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
