No brakes, need help!
Old Oct 14, 2002 | 10:26 AM
86 sports coupe's Avatar
Car: 86 sports coupe-83 berlinetta
Engine: 5.0 in the sports coupe-350 in the berlinetta
Transmission: 700r4 in the sports coupe-turbo-350 with a 2500 stal in the berlinetta
My car has disc brakes front and rear. the brakes never worked and still doesnt work. I have put new rotors ,pads, calipers on the front. replace 1 caliper turned rotors new pads parking brake cables(parking brake doesnt hold at all) replaced brake booster?
What else could it be master cylinder? the brakes wont lock up at all.
Old Oct 14, 2002 | 05:18 PM
Soulrev's Avatar
Car: Formerly - 87 T/A, 87 Bird.
Absolutely none of the brakes work? If not, gotta be your master cylinder. Check all the lines make sure there's no leaks and if you haven't already, bleed them. If that doesn't fix it I don't think you're gunna find much help here.
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
