my right rear brake is messed up... the outter pad seems to wear fine, but the inner pad is jacked up. only the top half of the pad is making a good contact to the rotor. i noticed this a while ago and had to get new rotors. the sound reapeared a few weeks ago....any suggestions?
hows the rotor? When you last changed your pads did you cut the rotors?
they were so bad that i had to get new ones. the brake job is only a bout a month old
Could possibly be a problem with your caliper. You can get stock replacements for like $15.
Quote:
i wish the rear calipers were that cheap!!! but i think it may be my caliperOriginally posted by Hulk0202
ebmiller88
close
What year is the car? Anyhoo, replace or rebuild your rear calipers. Check that your caliper slides move freely also. If they're stuck, it'll only engage one pad when you hit the brakes.
Ed
Ed
84 trans am, all wheel disk. so far i have replaced all the other calipers except this one.
