upgrading
Old Oct 14, 2002 | 04:04 PM
CamaroFreak87's Avatar
Car: 1987 Camaro IROC Z-28
upgrading
I want to set my car up for autocross and drag. not be extremely good at either, but good at both. First off, shocks/struts. How many adjustable points do I really need? 3 sounds good to me... next, springs. just go with the eiback pro kit? next, brakes. The brakes on my car work pretty good...they're stock 4wheel disc non-1le, but I was thinking the Baer Tracks with 13in rotors for the front. Do I need to get new ones for the back? Last, lift bars. I have a SSM Lift Bar kit on my drag car. it works hella good for drag applications. I want to use this kit on this car as well, will it affect handling? It stiffens the rearend up a lot. it's welded to the rearend on either side by bars which have pivot points on the SFCs. Thanks.
Ryan
Old Oct 17, 2002 | 04:13 PM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
In my opinion (and sure to start some debate)...
I think any mods for autocross will reduce the weight transfer that you want for drag racing and vice-versa. You want softly-sprung and valved suspension to transfer weight to the rear wheels if you have lots of torque to plant off the line in a drag race. Such a setup will increase brake dive and acceleration squat.
I would improve the front brakes and leave the rears alone. Going with a good aftermarket (large!) front brake setup should have you laughing. They're the ones doing all the work.
Old Oct 17, 2002 | 07:34 PM
the soft/hard needed for drag/autox was why I was thinking about adjustable shocks/struts. that way I can adjust their stiffness depending on what track I was at. I just don't know how many adjustable points I would need to make the adjustment from autox to drag racing and vice versa. springs I'll have set more for autoxing, though. Also, thanks for the reply.
Ryan
Linson
Oct 24, 2025 02:00 PM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
Zell1luk
Sep 29, 2015 10:36 AM
dbrochard
Sep 25, 2015 04:56 PM
