rear sway bar cam loose
Old Oct 16, 2002 | 01:58 AM
costill91Z's Avatar
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
Axle/Gears: 4.30 Dana 44 Rear 10 bolt front
my rear sway bar is bolted in at either end but is held in along the rear end by the bushings
where it should be bolted in is stripped out, take it to gm, or how can i fix this
is it bad to drive it like this?
thanks for the help
Old Oct 16, 2002 | 03:09 AM
vjo90RS8's Avatar
Car: 2002 Z28
if u are talking about the end links, just go and get some new ones, they are really easy to replace.
Old Oct 16, 2002 | 12:27 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Yeah, I agree. You should have no problem changing the ends and the bushings. New ones will probably be in order if you car has some mileage on it anyway.
Old Oct 16, 2002 | 07:46 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Replace both end link pieces with new ones. Don't waste your time trying to reuse the old junk, if it can be reused at all.
New stuff is coool
Attached Thumbnails rear  sway  bar cam loose-rearend-almost-completed-1
Old Oct 17, 2002 | 02:10 AM
costill91Z's Avatar
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
thanks for the pic.
Old Oct 17, 2002 | 02:46 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
ebmiller, nice axle! Did you find new u-clamps for the rear axle, too? I tried using a stainless steel muffler clamp when I put greasable bushings (from energy suspension) on the rear bar, but the u-bolt wasn't long enough. (Same, it looked sharp.) So i just wound up POR-15'ing the original u-bolt and clamp. Came out good, but a new clamp would've been a nice bonus. ('Course I would've had to notch the clamp to take the little plate on the bottom of the axle, the one that keeps the clamp from spinning...)
Old Oct 17, 2002 | 05:25 PM
ebmiller88's Avatar
Thanks Tom. No, not new. I just sandblasted everything and coated the parts in POR-15. I love that stuff. I'm doing another rearend and some subframe connectors in the stuff nest week.
Ed
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
z28addict8490
Aug 7, 2015 08:48 PM
