Caliper chatter
Old Oct 17, 2002 | 05:54 PM
chitowncruiser's Avatar
Car: 1996 Camaro
Engine: 3800 V-6
Transmission: 4L60E Automatic
Caliper chatter
hey guys i have a 92 firebird mostly stock, i get a chatter noise in the right side wheel when i cruise under 35 miles per hr, if i apply the brakes the noise goes away, sometimes i dont even get the noise at all....any hints on whats causing it to happen.....thanks
Old Oct 24, 2002 | 04:49 AM
Blackbari's Avatar
Car: 1988 IROC
Engine: B2L
Transmission: MD8
Axle/Gears: 2.77 9 Bolt
Worn Brakes?
It could be that you have worn brake pads, a worn outer wheel bearing, warped rotor or loose brake pad. Take off the wheel and check it out.
Old Oct 24, 2002 | 11:14 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
A problem that's typical with these type of GM floating calipers is the outter pad. If you look at it you will see 2 tabs on the top of it these should be bent down so that they fit snuggly against the caliper, actually the tighter you can get it the better. Often when new pads are installed they are never bent down, and this can sometimes cause the chatter noise that your describing. Because these are low drag calipers the piston is drawn back in it's bore slightly when the pedal is released, this is enough to cause the outter pad to bounce around if it's loose, when you apply the brakes it goes away.
Old Oct 26, 2002 | 06:14 PM
FORMULA355TPI's Avatar
Car: 88 FORMULA / 88 IROC
Engine: 355 / 355
Transmission: T5 / TH400
Axle/Gears: 10 Bolt-3.73 / 9"-3.90
On third gens with rear discs there should be a retainer clip either made form wire or thin steel keeping the inboard pad against the caliper puck if you are missing this the noise you described will be the result. Call your gm parts dealer for replacements if they do not know what you need e-mail me i can grab the part number from my files... Good luck
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
the_hamturdler
Sep 30, 2015 12:50 PM
