11 second GTA here. What wheel studs will I need?
Old Oct 23, 2002 | 07:12 PM
Joseph Andres's Avatar
Car: 1991 GTA Convertible
Is there an exact fit wheel stud that I can order from Jeg's or Summit? I have stock 26 spline axles (for now) with rear disc brakes. I'll need studs that are the same thread. I am using the stock GTA crosslace wheels with Mickey Thompson ET Streets. Any suggestions? Track rules require longer wheel studs for cars that run 11.99 and quicker.
Old Oct 23, 2002 | 08:17 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
There's nothing in the rulebook saying all cars must have longer studs. You only need longer studs if you use aftermarket rims that have a thick center section such as Weld Drag Lites.
The rules state that the stud must protrude into the hex portion of the nut at least the thickness of the stud.
Your 12mm studs must extend at least 12mm into the nut (not including the tapered part of the nut)
Old Oct 23, 2002 | 08:24 PM
AlkyIROC's Avatar
Car: 87 IROC L98
You'll need a lot more than that anyway to run in the 11's.
Minimum 5 point (everyone does the extra bar for a 6 point) roll bar. Single layer fire jacket. 5 point harness. If the tires are tubeless, they must have metal screw in valve stems. An SFI rated harmonic balancer. These are all the extras needed for your car to go into the 11's.
Aftermarket axles and a positive axle retention device (Ford 9", c-clip eliminators, rear disk brakes) are required at 10.99 but you should have them at 11.99 just to be safe.
1992rs/ss
Jan 31, 2025 05:10 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
transaero
Aug 31, 2015 01:14 AM
Dialed_In
Aug 20, 2015 01:45 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
