Z28/RS spindles different?...
Old Nov 3, 2002 | 01:49 AM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
just wondering if they are any different. Cause my drop spindles should be in soon and it said Z28. I'm wondering if I will have to convert to Z28 rotors and calipers. Do I?
Old Nov 3, 2002 | 02:50 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
There are 2 kinds of spindles, the standard (later 3rd gens had beefier ones) and the 1LE (which is a modified std).
Old Nov 3, 2002 | 03:37 AM
REVLIMIT's Avatar
Engine: Built L98
I see...so I atcually dont have to convert to Z28 brakes? I can use these Z28 spindles with my RS brakes?
Old Nov 3, 2002 | 01:57 PM
Z28 and RS brakes are the same. Unless you have 1LE, you can interchange the parts.
Old Nov 3, 2002 | 04:03 PM
REVLIMIT's Avatar
Engine: Built L98
O_o but the Z28 rotors are bigger and the calipers would have to be farther from the spindle....oh well I'll just check when they come in if I'll need to swap to Z28 brakes or not.
Old Nov 3, 2002 | 06:27 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Where did you get this bit of
The brakes on a Z28 and a RS are the same UNLESS you have a 1LE system...there is NO difference.
Here's the stock brakes on my Iroc Z28:
Attached Thumbnails Z28/RS spindles different?...-front-suspension-again-1
Old Nov 3, 2002 | 06:28 PM
ebmiller88's Avatar
Here's my 1LEs. See the difference???
Attached Thumbnails Z28/RS spindles different?...-caliper-hose-installed-2
Old Nov 3, 2002 | 06:30 PM
ebmiller88's Avatar
Here's what the 1LE spindle looks like:
Attached Thumbnails Z28/RS spindles different?...-greasing-spindle-1-..jpg
Old Nov 3, 2002 | 06:31 PM
ebmiller88's Avatar
And here's what the stock Z28/RS spindle looks like. They're the same single piston iron floater caliper style.
Attached Thumbnails Z28/RS spindles different?...-loosening-strut-1-..jpg
Old Nov 3, 2002 | 06:35 PM
ebmiller88's Avatar
Supposedly there IS a difference between 15" and 16" A-arms but I don't kow exactly what that is. Both my cars came with 16s so I dunno.
Ed
Old Nov 3, 2002 | 10:13 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
The A arms are identical. Except for the steering stop. The steering stops are different on cars with 16" wheels to prevent tire to body contact.
Thanx,ANDYZ28
Old Nov 4, 2002 | 01:16 AM
CrazyHawaiian's Avatar
Car: too many ...
would having 1LE A-Arms help prevent tire to body contact more than my stock RS A-Arms?
Old Nov 4, 2002 | 03:45 AM
ebmiller88's Avatar
No such thing as "1LE A-arms", only spindles. If you're getting tire to body contact from those crazy assed slides you do (), I'd go with stiffer springs and struts. However, if you're getting the contact when the wheels are turned, they're probably gonna hit the fender lip anyway.
Ed
Old Nov 4, 2002 | 05:19 AM
REVLIMIT's Avatar
Engine: Built L98
the only difference I know of the 1LE a arms is that they have poly bushings. I dont think their longer
Old Nov 4, 2002 | 08:01 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Only two A arms are available, for 16" wheels and non-16" wheels. The difference is the steering stop that is rivited to the A arm.
Thanx,ANDYZ28
Old Nov 4, 2002 | 04:50 PM
Car: too many ...
Ed
I bought a set of Factory 1LE A-Frames , lightened , custom solid bushings welded in from TVP's roadracing project garage sale. Now I'm kinda confused, are these the A-Arms or the spindles? I assumed that 1LE anything was better than my stock RS pieces (came with 15" wheels) so I just bought what sounded like it would make an improvement. Ended up with the 1LE A-Frames, 1LE front sway bar, 1LE Lower Control Arms, and a WS6/F41/1LE quick ratio steering box. What do you think?
Old Nov 4, 2002 | 06:42 PM
90iroc5spd's Avatar
Car: 87 aniv vert, 90 Iroc, 87 LT
Engine: LB9, LB9, carbed 305
Transmission: MM5, MM5 conversion, MM5 conversion
Axle/Gears: 3.45, 3.73, 3.73
hey crazy, your problem was that you assumed, those are the a-arms, and as said there is no difference in the a arms on a 1LE. the only difference in the ones that you bought was what the previous owner did to them, which i would be worried about strenght wise. (i was looking at those arms you bought, and i was kind of skeptical) if you wanted lighter arms, tubular would have been the way to go.----except i have yet to see tubular arms with a provision for the sway bar, i guess since thats more of a drag race mod.
Old Nov 4, 2002 | 08:54 PM
REVLIMIT's Avatar
Engine: Built L98
I talked to PA racing and they have sway bar ones. But you have to order them straight from PA. I guess they have to special make them.
Pac J
May 17, 2020 10:44 AM
Mark_ZZ3
May 24, 2018 01:02 PM
383backinblack
Oct 14, 2015 08:50 PM
jdperformance
Sep 16, 2015 11:55 AM
rb85TA
26
Sep 14, 2015 10:29 PM
