Are the Bilstein front struts suppose to be shorter than stock??
Old Nov 4, 2002 | 11:05 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
I purchased a set of Bilsteins and noticed that they were shorter than stock.
Old Nov 4, 2002 | 01:33 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
they have 2 option in strut/shock kits.
HD, for stock height cars.
SP, for lowered cars.
i called bilstein , because the front strut # is the same for both kits, but the rear shock # is diffrent, the bilstein technicians told me the front STRUT is IDENTICAL for both kits, but the rear shocks are desgined diffrently for the lowered aplication vs the stock height aplication.
this would tell me that no matter which kit you got, the front struts should be "Close" to the stock length.
How much shorter are the bilsteins than stock? are we talking 1/32" or 2"?
if you have anymore questions bilsteins north american tech line is
1-800-537-1085
Old Nov 4, 2002 | 03:10 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
They were about an 1" - 1 1/2" if I remember correctly. At time of installment I compared them to a pair of KYB's I origanally had installed.
Old Nov 4, 2002 | 07:46 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
IIRC, my Bilstein struts were about the same height as my KYB GR2s.
Old Nov 5, 2002 | 11:03 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
do they come compressed?? Are you suppose to unlock the shaft like you do with some struts??
Old Nov 5, 2002 | 11:04 AM
Dewey316's Avatar
Car: 1990 Camaro RS
i would give the 800# above a try.
Old Nov 9, 2002 | 05:34 PM
Eightyninef's Avatar
put the struts in, they work. I have em
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
TheExaminer
Aug 25, 2015 07:34 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
1992 Trans Am
Aug 9, 2015 04:32 PM
