pinion angle ?
Old Nov 17, 2002 | 11:22 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Transmission: TH-400
Axle/Gears: 4.11
pinion angle ?
i am installing an adjustable torq arm this week , where should i set the pinion angle ? what do others set them at ? see my sig. for the car .
help i need traction!
thanks
mike
Old Nov 18, 2002 | 06:10 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
For yerbasic street car with street tires, about 1 - 1½° negative (pinion that much lower than the drive shaft) works about the best. For a really max-effort race car, somewhere around 4° negative is more typical.
A torque arm by itself probably isn't going to do a whole lot for your traction by itself, especially if your car is lowered. You need LCA lowering brackets.
Old Nov 18, 2002 | 01:51 PM
AFreaknGoodTme's Avatar
He is correct, I just want to add that it is the relation of the angle of the transmission output shaft angle measured against the angle of the pinion. Match the pinion angle to the same angle of the output shaft for starters, then angle the front of the pinion downward (or negitive) 1* and you should be fine. If it is a higher torque motor and it is strictly used of drag racing, then you will want to adjust more towards the 2*,3*, or even 4* mark but this is getting extreme for street use. Drag cars are only run under hard thrust conditions,and if they were to ease off the throttle for driving normal freeway crusing speeds, the would develop bad harmonics in the drivetrain. (a.k.a.- the waa-waas)
Old Nov 18, 2002 | 07:29 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Axle/Gears: 4.11
thanks guys
those answers should help a lot ]
i have s&w race cars SFC and torq arm comming, the torq arm hooks to a crossmember on the SFC . spohn adj. panard rod, and lower control arms , plus their relocation brackets . the TA performance rear end girdle showed up today . and moser axels will be here this week also. just wasn't sure how to adj. any other suggestions? i plan on either comp. drag radials , or m&h street slicks by spring
mike
jbates346
Oct 21, 2015 01:50 PM
gord327
Oct 3, 2015 01:25 PM
gord327
Sep 29, 2015 10:18 PM
mfp189
Sep 27, 2015 09:25 AM
dimented24x7
Sep 17, 2015 06:58 AM
