3rd gen Rear Drum to Disc Swap??
Old Nov 17, 2002 | 12:41 PM
89fastlookinRS's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
I am thinking of buying a rearend from a mid 80's trans am that has discs on it. My 89 rs has drums, so what do I need if anything to change this over.
Thanks.
Old Nov 17, 2002 | 01:47 PM
MdFormula350's Avatar
you most likely need the parking brake cables, the rear end of coarse, and the proportioning valve from the master cyclinder..
Old Nov 19, 2002 | 04:00 AM
scott92RS's Avatar
Car: 92 Firebird
Engine: 350 TBI/LT4 cam
Transmission: 700R
How much of the parking cables will be needed?
Old Nov 19, 2002 | 09:49 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I assume that you don't want to spend the extra cash on the late model discs. I am unfamiliar with the early model setup. Make sure that the cables connect in the same fasion that they do now. The later models have a Y bracket that each side connects to. Don't be surprised if you have to replace both of the calipers.. they are prone to crapping out.
1992rs/ss
Jan 31, 2025 05:10 PM
jaridjohn
Jul 8, 2024 03:49 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
